Just received my KVM-GO DP version and am excited to use it. The easiest setup I can do at the moment is to use my Lenovo thinkpad as a host and my Macbook pro as the target. I can’t do it the other way around because Mac is locked down completely, so I can’t install the openkvm software.
The mac recognizes the keyboard just fine (and it requests me to do the keyboard type identification). However, the display never shows up as a secondary display in the displays control panel.
Questions:
Is there a verified usb-c to DP adapter that is verified to work?
In the alternative, I guess I could use a HDMI-> DP adapter, but I’m not sure how reliable that would be.
Just to narrow this down first: have you tried connecting the Anker USB-C-to-DP adapter directly from your MacBook to a regular DP monitor, if you have one? Does the Mac detect the monitor and output video normally with that setup?
Just be careful with the direction here: HDMI → DP and DP → HDMI are not the same thing. For HDMI output from the Mac to the DP input on KVM-GO, you’ll need an active HDMI-to-DisplayPort converter that specifically supports HDMI source → DP display. These converters often also require USB power.
BTW, which exact MacBook Pro model/year are you using? That would help us better understand the video output options on the Mac side.
Target is a 2024 Macbook Pro. This is the 16" model with an m4 pro chip.
God idea about testing the Anker USB C DP adapter directly. I tried that and couldn’t get it working direct to the monitor. The adapter does work between my thinkpad and hmm.. it acts weird and doesn’t work.
I hear the audio feedback that a usb device is connected. In displays, the monitor is detected, but I can’t change any settings and if I go into advanced display options it says the display is not detected. Seems like maybe there is an incompatibility between the computer/adapter/monitor. This will take more investigation.
I’ve ordered a HDMI to DP adapter and a different brand (cable matters) thunderbolt → displayport adapter. Will see if that behaves any better. Should arrive tomorrow evening.
For this particular use-case I should have probably just ordered the HDMI version of the kvm-go. I’m getting into the cost of the device with all the adapters. (sigh)
Can you perform a test using the system built-in camera on our device (Openterface)? Or, from the soft menu bar Control >> Device then select the device
So I can at least confirm that from my thinkpad the cable matters tb → dp adapter works when connected directly to my monitor. So it seems to be an issue with the Anker one (either defective or just not compatible).
I connected it up to my macbook and this is what I see:
First impression was that the capture was very fuzzy. Going to the Video settings, I’m unable to change the capture resolution to 4k. So, the mac is putting out a 4k signal, but then the capture is only 1920x1080 (30-60hz) and then I can choose framerates from 30-120.
I believe this would be an issue between the host computer (thinkpad) and the kvm-go. In fact, when doing an environment check, I get a notice about the signal and capture settings differing and that I need to make them agree.
I’m using the latest version of the openinterface application according the help->update. 0.5.28.230.
Another question is that when I choose full-screen mode, the actual screen is NOT 1-1 full screen. I still see the menu bar + buttons along the top which then makes the screen get compressed vertically.
My use case is to control the target as if the host is not there (while still allowing me to quickly go back and forth between host and target). Having the chrome of the openinterface application still present prevents me from doing that.
Finally, even with my simple testing the unit gets very hot. I’m assuming that is ok?
The device being hot is a normal phenomenon. You could try updating to the latest version 0.5.30 and switching the video settings in preferences to use media foundation instead of ffmpeg, which may solve the issue of blurriness. Additionally, having the Chrome toolbar present may cause compression because the Mac’s aspect ratio is 16:10 instead of 16:9. We plan to remove this toolbar in future updates for full-screen mode.
