[From Discord] How to troubleshoot multiples issues aka raw serial connection ?
Imported from Discord — originally posted by Zwei on 14 November 2025.
Hi,
I’m under Linux (NixOS 25.05 stable), KDE Plasma 6 and trying to control another device under Linux (KDE Plasma 6).
device is : Openterface Mini-KVM (all USB-C/USB-A/HDMI cables used are from the original box)
I’m having a lot of issues at the moment with the device, I don’t even know where to begin :
  • Video feed was working and keyboard was not, serial reset did not change anything so I thought let’s do a firmware upgrade
  • I’ve done a firmware upgrade to the latest version => firmware version becomes => 00000000 after firmware upgrade, before it was showing something at least
  • Video feed is using a camera that is not even related to Openterface device, showing camera feed of a device plugged in my computer (which is completely unrelated, I’ve unplugged or disabled that camera device).
  • Keyboard doesn’t work
  • USB 2.0 Switchable port does not work (works only for host)
  • After firmware upgrade => reset Serial port causes segmentation fault of Openterface-QT which is quite nice
  • Video feed no longer shows up, even after unplug/replug every cables
I’ve enabled logging in the openterface-QT and the log file is empty even if I tick every box in the GUI.
Hmm, is there something that can work ? What can I do to troubleshoot by this point ? (because it is taking me a lot of time just to get something working atm)
Originally posted by Kevin Peng on Discord, 17 November 2025.
Hi Zwei, I am sorry to hear your experience, I think the main issue you encountered is because you didn’t get the HID permission in the app before it is working. I supposed your firmware upgrade will not succeed, as the Firmware upgrade rely on the HID communication.
Although I don’t have experience on NixOS, but I think I can install one to have a test on your scenario.
Before I go deep into testing, I would like to check with you if you have Windows or MacOS machines, you can use the firmware restore function to recover the firmware. If you have, I will give you a link to download the latest firmware
Originally posted by DayJobWorkAccount on Discord, 18 November 2025.
I’m having some similar issues with my unit on Windows 11 as @Zwei is - software is crashing and serial port not functioning properly.
Originally posted by Kevin Peng on Discord, 18 November 2025.
Can you try the 0.3.19? It is more stable than the latest version. We found some problems at latest version and we are working on the fix.
Originally posted by Zwei on Discord, 19 November 2025.
I probably could use Windows but I’m skeptical that HID communication weren’t working as the first firmware upgrade did go through it seems, I can try the 0.3.19 or latest with recovery firmware on Windows
And I also did setup a lot of the udev rules things made sure to reboot and made sure that /dev/hidraw* devices could be opened by the openterface-QT before doing any upgrade on Linux
Regarding NixOS, any Linux system can use the Nix package manager but basically I would say it’s a bit the same as any official Linux distro, testing on Debian or Arch Linux would probably be similar (it is just Linux with different bits of software used but some are the same, mainline Linux kernel and so on)
Originally posted by Kevin Peng on Discord, 19 November 2025.
We did a lot of test on Debian base Linux, eg: Ubuntu and Raspberry Pi OS, so the settings should be the same like you said.
Udev rules :
 73   │ # Openterface udev rules
  74   │
  75   │ KERNEL=="hidraw*", SUBSYSTEM=="hidraw", MODE="0660", TAG+="uaccess"
  76   │ SUBSYSTEM=="usb", ATTRS{idVendor}=="534d", ATTRS{idProduct}=="2109", TAG+="uaccess", MODE="0660"
  77   │ SUBSYSTEM=="hidraw", ATTRS{idVendor}=="534d", ATTRS{idProduct}=="2109", TAG+="uaccess", MODE="0660"
  78   │ SUBSYSTEM=="ttyUSB", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", TAG+="uaccess", MODE="0660"
  79   │ SUBSYSTEM=="usb", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", TAG+="uaccess", MODE="0660"
I added the line :
In order to allow hidraw devices to be opened by user in group uaccess and the destkop Openterface-QT appImage seems to not be able to detect that the rules are properly setup (everytime I launch the app it is asking me to set them up again, which I don’t do as they are setup)
If there is a serial port device I can open or check if it’s possible to open it manually, let me know
Can you share me the dmesg log since the device plugged in?
You can use “lsusb” to see if all drivers ok
There is a serial tool at advanced menu, you can check the serial communications.
I believe these are relevant logs :
https://cdn.discordapp.com/attachments/1438942520427024445/1440511378761977978/message.txt?ex=6a4ef6c4&is=6a4da544&hm=201b49c18a15c94de640b4bcbb64850e182f77c6fbd2d61f28229dc905d65ce4&
It looks like this is a driver issues, the serial disconnected after it detect for a while
Should I try Linux LTS maybe and see if that works better ?
Currently I’m on the latest stable mainline kernel 6.17.7
you may need to install the Ch34x driver from this repo
GitHub - WCHSoftGroup/ch341ser_linux: USB to serial driver for USB …
USB to serial driver for USB to serial chip ch340, ch341, etc. - WCHSoftGroup/ch341ser_linux
Yes, in order to recover your device first. Then you can try other newer distributions after the firmware recovered
Later I see that the device was failling to even just connect at all :
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1: clear tt 1 (90d2) error -71
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1.2: failed to send control message: -71
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1: clear tt 1 (00d0) error -71
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1.2: failed to receive control message: -71
nov. 14 17:23:10 Sakabato kernel: ch341-uart ttyUSB1: failed to read modem status: -71
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1: clear tt 1 (80d0) error -71
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1: USB disconnect, device number 15
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1.1: USB disconnect, device number 16
nov. 14 17:23:10 Sakabato kernel: usb 7-1.3.1.2: USB disconnect, device number 19
nov. 14 17:23:10 Sakabato kernel: ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
nov. 14 17:23:10 Sakabato kernel: ch341 7-1.3.1.2:1.0: device disconnected
This has caused segmentation fault of the Openterface-QT but I don’t know exactly when it started happening is it after the firmware update or before, I’m not sure at the moment, I would need to retry plugging the USB device first
And I know the latest OpenterfaceQT app has some bugs related to plug and play detection. And our developer was actually fixed at latest GitHub, but get stacked at packaging of the Windows portable version due to changed too much in one release.
Originally posted by DayJobWorkAccount on Discord, 26 November 2025.
0.3.19 Seems to be working much more reliably for me on Windows than 0.5.x; thanks!
