Originally posted by Virtual-Potato on Discord, 10 June 2025.
It probably depends on what your situation is, and will likely vary depending on the exact model of your laptop.
For example, if the laptop’s screen is currently non-functional, then it might be a bit difficult to figure out without a reference system to compare it with.
However, if you just want to be able to use an external monitor to control the BIOS from now on, you might be able to configure a setting in the BIOS to set the default display device.
Look through the BIOS menu options for something called “Boot Display Device” or similar. It’ll likely be set to internal display - you’d want to change that setting to use an external display.
