[From Discord] Mac works, Win10 not so much
Imported from Discord — originally posted by puffytacos on 5 November 2025.
i installed the host app on my mac and plugged everything in and it worked fine. I just tried hosting on my windows 10 machine and when i connect everything, I just see the quick start guide. Is there any troubleshooting guide? I couldnt find one online. Any help to a troubleshooting guide or steps would be much appreciated.
I noticed something (maybe strange).. I appear to have two OpenNterface devices on windows. Port 1-1.2 and Port 1-6.2. i flipped between them and neither seems to work, but not sure that could be an issue.
Originally posted by puffytacos on Discord, 5 November 2025.
Also I enabled logging, but I dont see any errors or messages that say something is broken.
This might mean something? Devices are not complete?
2025-11-05 13:54:42.118 [opf.device.windows] [D] === DEVICE DISCOVERY SUMMARY === (:0, )
2025-11-05 13:54:42.119 [opf.device.windows] [D] Total Openterface devices found: 2 (:0, )
2025-11-05 13:54:42.120 [opf.device.windows] [D] Device[ 0 ] Summary: (:0, )
2025-11-05 13:54:42.120 [opf.device.windows] [D] Port Chain: “1-1.2” (:0, )
2025-11-05 13:54:42.121 [opf.device.windows] [D] Instance ID: “USB\VID_1A86&PID_7523\6&121C6518&0&2” (:0, )
2025-11-05 13:54:42.122 [opf.device.windows] [D] Interfaces: “Serial(COM3)” (:0, )
2025-11-05 13:54:42.123 [opf.device.windows] [D] Serial: “COM3” (:0, )
2025-11-05 13:54:42.124 [opf.device.windows] [D] HID: None (:0, )
2025-11-05 13:54:42.125 [opf.device.windows] [D] Camera: None (:0, )
2025-11-05 13:54:42.125 [opf.device.windows] [D] Audio: None (:0, )
2025-11-05 13:54:42.126 [opf.device.windows] [D] Complete Device: No (:0, )
2025-11-05 13:54:42.127 [opf.device.windows] [D] Device[ 1 ] Summary: (:0, )
2025-11-05 13:54:42.128 [opf.device.windows] [D] Port Chain: “1-6.2” (:0, )
2025-11-05 13:54:42.128 [opf.device.windows] [D] Instance ID: “USB\VID_1A86&PID_7523\6&3923BF4&0&1” (:0, )
2025-11-05 13:54:42.129 [opf.device.windows] [D] Interfaces: “Serial(COM3)” (:0, )
2025-11-05 13:54:42.130 [opf.device.windows] [D] Serial: “COM3” (:0, )
2025-11-05 13:54:42.131 [opf.device.windows] [D] HID: None (:0, )
2025-11-05 13:54:42.131 [opf.device.windows] [D] Camera: None (:0, )
2025-11-05 13:54:42.132 [opf.device.windows] [D] Audio: None (:0, )
2025-11-05 13:54:42.133 [opf.device.windows] [D] Complete Device: No (:0, )
2025-11-05 13:54:42.134 [opf.device.windows] [D] === END DISCOVERY SUMMARY === (:0, )
Found this in the Device Selector:
Openterface Mini KVM Device
USB Port: 1-1.2
Device Instance ID: USB\VID_1A86&PID_7523\6&121C6518&0&2
Last Seen: 2025-11-05 14:08:04
Physical Device Overview:
Available Interfaces: 1/4
Device Status: 1/4 interfaces | Available
Physical Location: USB Port 1-1.2
Interface Details:
Serial Interface: COM3
Device ID: USB\VID_1A86&PID_7523\6&121C6518&0&2
Function: Control and communication
:cross_mark: HID Interface: Not available
:cross_mark: Camera Interface: Not available
:cross_mark: Audio Interface: Not available
Usage Instructions:
• Select this device to use all available interfaces
• The device will be activated for serial communication
• HID interface will be available for keyboard/mouse control
• Camera and audio interfaces will be available for capture\
this help?
App: 0.5.3.289OS: Windows 10 Version 22H2QT: 6.5.3
Permissions:MicrophoneAvailableVideoNot available or permission not granted
Environment Variables:
QT_QPA_PLATFORM: (not set)
XDG_SESSION_TYPE: (not set)
WAYLAND_DISPLAY: (not set)
DISPLAY: (not set)
I have a Hawk Sterling USB keyboard adapter. I wonder if that’s causing some sort of conflict? I hear it vibrate every so often when I start the OpenNterface app. I can now see the screen, but the target mouse and keyboard in the lower right of the status bar are red.
Originally posted by Kevin Peng on Discord, 7 November 2025.
Hi, sorry for late reply. I will help you for troubleshooting.
  1. Which version of Openterface you have on hand? Toolkit or Basic?
  2. What is your target device?
  3. The keyboard adapter sit between the Openterface target port and your target device?
Here is a troubleshooting guide, you can have a look, https://docs.google.com/forms/d/e/1FAIpQLSd4NiKDb-BRIJxuo5m08sC03nkhsioE-4KZj6e_uMZ6oDg5Bw/viewform?usp=dialog
And I suggest you change the baud rate or reset hid chip to factory to have a try
Originally posted by puffytacos on Discord, 7 November 2025.
  1. I have the toolkit.
  2. target device is a lenovo thinkpad type 21HG
  3. No the keyboard adapter is connected to the computer via bluetooth and communicates on the COM ports. The link to the project info is here, but when I disconnected it and tried the kvm it still didnt work, so I’m not sure it has anything to do with the issue. channel: Discord FAQ: Discord
I have changed to 9600 and tried at the higer rate as well. Neither seems to work. I reset the HID chip also and that didnt help.
I will fill out the troubleshooting form as well. Thanks for your help
Originally posted by Kevin Peng on Discord, 8 November 2025.
We will look into your from, thanks.
Originally posted by puffytacos on Discord, 10 November 2025.
thanks. let me know if you need more info.
Originally posted by Kevin Peng on Discord, 11 November 2025.
Hi, we are doing some testing against your form, the main issue we found is that there are two device one call mini-kvm, one call Openterface, which is not our expected result.
I suggest you downgrade to 0.3.19 version, that is a more stable version
Originally posted by puffytacos on Discord, 11 November 2025.
I’ll give that a try now. I did notice that one device was like 1.6.2 and the other 1.9 something or other
that did help. I can control and see the target. thank you! I only see one device and the device details are showing up in the device selector.
Originally posted by Kevin Peng on Discord, 12 November 2025.
good to hear that, then it’s a software issue, and I will try the same setting to simulate this problem. Likely the recent change break some logic, thank you for reporting this.
BTW, are you a Beta tester of KVM Go? and you are using KVM Go?
Originally posted by puffytacos on Discord, 12 November 2025.
The Go is the newer version right? If so I’m not a beta tester, but I would be happy to test if you need folks. I don’t have a kvm Go, just the toolkit version, but I’m happy to test new things on it too. I noticed that the old version of the software is just laggy enough to notice it. The newer version seems more responsive. I havent reviewed all the changes that have been made since 0.3.19, but I’m sure there were many upgrades and improvements so when you have a new version I will def test her.
Originally posted by Kevin Peng on Discord, 13 November 2025.
Yes, the KVM Go is the new version, and from your screenshot, I saw the software may mis-detected your device as KVM-Go. This shows that our regression test was not good enough to cover in the environment you are running.
We will improve the testing and release the fix soon, the new software will have better performance.
