Overview
During the hardware production testing of KVM-Go, we identified an opportunity to improve the internal power architecture and made a hardware change to improve the stability and reliability of the MicroSD reader and the overall system.
The production hardware therefore differs slightly from the original beta testing hardware. In particular, the MicroSD reader’s power source and Host/Target power isolation were revised.
Unfortunately, we did not update the MicroSD documentation to reflect this hardware change at the same time. This has resulted in some confusion, especially around using the MicroSD reader from the Host side when the Target device is not powered.
We apologize for the confusion.
The following information describes the behavior of the current production KVM-Go hardware and explains the reason for the change.
Production Hardware Behavior
For the production version of KVM-Go:
The MicroSD reader is powered through the Target USB connection.
The Target USB connection must be connected and powered for the MicroSD reader to operate.
Connecting only the Host USB port will not power the MicroSD reader, so the MicroSD card will not be detected.
When both Host and Target USB connections are connected, the MicroSD reader works normally.
Once powered, the MicroSD card can be switched between Host and Target using either the physical switch or software control.
Connection Summary
| USB Connection | MicroSD Reader |
| Host only | Not available |
| Target only | Available |
| Host + Target | Available |
| Host + Target, switched to Host | Available to Host |
| Host + Target, switched to Target | Available to Target |
Tip: Using KVM-Go as a Standalone MicroSD Reader
If you want to use the KVM-Go only as a MicroSD card reader, eg: for ISO copying, without using it for KVM control, you can simplify the setup:
Connect the KVM-Go directly to the Target device.
The current production firmware selects the Target side as the default MicroSD connection. Therefore, when the KVM-Go is connected directly to the Target, the MicroSD card should be available to the Target without requiring a Host connection.
This is the recommended setup when you only need the MicroSD reader and do not need the KVM functionality.
Note: The current firmware’s default MicroSD selection is Target, which differs from the behavior currently described in our documentation. We will update the documentation to reflect the production hardware and firmware behavior.
Important: Accessing to the MicroSD Card from the Host Before Powering the Target
A common use case is to use the KVM-Go to prepare a MicroSD card from the Host computer—for example, writing an operating-system ISO image to the card before booting or powering on the Target device.
With the production hardware, there is an important limitation:
The MicroSD reader requires power from the Target USB connection.
If the Target device is completely powered off and its USB port does not provide power while the device is off, the KVM-Go’s MicroSD reader will also not receive power.
In this situation:
Connect the Host USB to the Host computer.
Connect the Target USB to the Target device or power the target USB by power bank.
If the Target is powered off and does not provide USB power, the MicroSD reader will not be available.
As a result, the Host may not be able to detect the MicroSD card or write an ISO image to it.
Therefore, if you need to prepare or write an ISO image to the MicroSD card from the Host before booting the Target (eg: Boot from Ventory), please make sure the Target USB power is on.
If the Target hardware does not provide standby USB power, you will need to power the Target USB connection through another suitable powered USB source before using the MicroSD reader from the Host.
Important: The Target device does not necessarily need to be fully operational, but the KVM-Go’s Target USB connection must provide power to the MicroSD reader.
Why Was the Hardware Changed?
The beta version used a shared internal power architecture in which power from the Host and Target sides passed through power-management components before being supplied to the internal circuits.
During hardware development and testing, we identified that the voltage available to the MicroSD controller could be reduced by voltage drop in this power path, the ideal diode false alarm!! The MicroSD controller is more power demanding than Keyboard and Mouse controller chip. Because the MicroSD controller requires a stable 5V supply, this could potentially cause unstable MicroSD operation or card detection problems.
For the production version, we redesigned the power architecture to provide a more stable power supply and better isolation between the Host and Target sides.
This design also helps prevent unwanted current flow between the two USB power sources when both are connected.
Why Does the Target USB Connection Need to Be Connected?
The production hardware supplies power to the MicroSD reader from the Target side.
The Host/Target switch determines which device has access to the MicroSD card, but it does not change the power source of the MicroSD reader itself.
Therefore, even when the MicroSD switch is set to Host, the Target USB connection is still required to power the MicroSD reader.
This is an intentional characteristic of the production hardware design.
Beta Hardware vs. Production Hardware
The beta testing hardware used an earlier internal power architecture, so its behavior may differ from the production version.
The production hardware uses the revised power architecture described above. Therefore, users who tested a beta unit may notice that the MicroSD reader behaves differently on the production unit.
This change was made as part of the hardware engineering process to improve:
Power stability
Electrical isolation between Host and Target
Protection against unwanted current backflow
Overall hardware reliability
The difference between the beta and production hardware is therefore intentional and related to the hardware power design, rather than a software or MicroSD compatibility issue.
Recommended Setup
For normal KVM-Go operation with the MicroSD reader, we recommend connecting both the Host and Target USB connections.
If the MicroSD card needs to be accessed by the Host, simply switch the MicroSD connection to Host using the physical or software switch after power on.
If you only need the MicroSD reader and do not need KVM functionality, simply connect the KVM-Go directly to the Target device.
If you need to write an ISO image to the MicroSD card from the Host while the Target is powered off, make sure the Target USB connection still provides power. Otherwise, the MicroSD reader will not be powered and the Host will not be able to access the card.
Important: On production KVM-Go units, the Target USB connection must be connected and powered for the MicroSD reader to operate, even when the MicroSD connection is switched to Host mode.
