[From Discord] K/B Issues with WIn11 and Mini-KVM
Originally posted by Billiooo on Discord, 23 November 2025.
You can always ping us. We’ll help out. Just sometimes we might be a bit slow to reply.
Originally posted by Selcouth on Discord, 23 November 2025.
Great to hear, will you respond here when there’s a fix out or do a serverwide ping?
Also, if I go back to a previous version of the software I still have the same issue. Would that still be the case?
Originally posted by Kevin Peng on Discord, 24 November 2025.
2025-11-21 21:30:26.119 [opf.core.serial] [D] Attempting to switch to serial port by port chain: “1-2.2” (:0, )
2025-11-21 21:30:26.119 [opf.core.serial] [D] Found 1 device(s) for port chain: “1-2.2” (:0, )
2025-11-21 21:30:26.119 [opf.core.serial] [D] Found device with serial port: “COM4” (:0, )
2025-11-21 21:30:26.119 [opf.core.serial] [D] Switching serial port from “” to “COM4” (:0, )
2025-11-21 21:30:26.119 [opf.core.serial] [D] Initializing serial port with HID chip configuration (:0, )
2025-11-21 21:30:26.119 [opf.core.serial] [D] Serial port connected: “COM4” (:0, )
2025-11-21 21:30:26.121 [opf.core.serial] [D] Detected VID:PID = “1A86” : “7523” for port “COM4” (:0, )
2025-11-21 21:30:26.121 [opf.core.serial] [2025-11-21 21:30:26.121][30756] (:0, )
2025-11-21 21:30:26.121 [opf.core.serial] [D] No stored baudrate found, using default: 9600 (:0, )
2025-11-21 21:30:26.121 [opf.core.serial] [W] Serial port error occurred: “Access is denied.” Error code: 2 (:0, )
2025-11-21 21:30:26.121 [opf.core.serial] [C] Critical serial port error, immediate recovery needed (:0, )
2025-11-21 21:30:26.122 [opf.core.serial] [C] Maximum retry attempts reached. Giving up recovery. (:0, )
2025-11-21 21:30:26.122 [opf.core.serial] [W] Failed to open port on attempt 1 Error: “Access is denied.” (:0, )
2025-11-21 21:30:26.122 [opf.core.serial] [D] Check serial port (:0, )
@Selcouth I checked with the logs you provided, you didn’t get the access right to the serial port, I would like to double check if you are running with a user without admin right?
Originally posted by Selcouth on Discord, 24 November 2025.
I’m running as myself, which has full admin privileges
Originally posted by Kevin Peng on Discord, 3 December 2025.
@Selcouth would you mind to try the latest OpenterfaceQT version to have check if your issue resolved? If not, I am happy to troubleshoot with you through google meet
Originally posted by Selcouth on Discord, 3 December 2025.
I actually tried it yesterday, it worked briefly, but the display was messed up, almost out of focus. I unplugged to reset and I haven’t got the keyboard and mouse to work since.
Would love to do a Google meet, maybe it’s just something simple idk
The keyboard and mouse are working this morning, but the display is still terrible
Originally posted by Kevin Peng on Discord, 4 December 2025.
feel free to book the Google Meet here, https://openterface.com/support/appointment/
