Gibby
July 8, 2026, 4:58am
1
Imported from Discord — originally posted by digi-tal on 20 May 2025.
I tried my Openterface for the first time today and am having some issues.
Hardware: Via Mini-ITX using VGA adapter supplied with the kit.
Host: Windows 11
I could NOT see the BIOS
I could see the “Windows CE” loading screen.
I could NOT see the Windows CE desktop.
Can anyone help?
Gibby
2
Originally posted by Billiooo on Discord, 29 May 2025.
@Kevin Peng @user-1280746397511061567
Gibby
3
Originally posted by Kevin Peng on Discord, 29 May 2025.
“I could see the “Windows CE” loading screen.” you mean you can see the Windows CE screen through the VGA adapter just for a short time, right?
Gibby
4
Originally posted by digi-tal on Discord, 30 May 2025.
Correct, just a couple of seconds.
Gibby
5
Originally posted by digi-tal on Discord, 24 June 2025.
@Kevin Peng @Billiooo @user-1280746397511061567 any thoughts on this? This setup is my primary use case.
Gibby
6
Originally posted by Kevin Peng on Discord, 27 June 2025.
With a normal VGA monitor connected, can you check the WinCE can output 1080p resolution?
Gibby
7
If you are using the Openterface QT software on Windows host or Linux host, you can try to change the capture resolution to 800x600 or 640x480 in preference menu to check if you can see the screen
Gibby
8
I guess likely your Window CE outputs a non-standard resolution that the VGA to HDMI adapter not support
Gibby
9
Originally posted by digi-tal on Discord, 3 July 2025.
Thanks for the input, I have been using an AURGA viewer, I can try the VGA adapter I used with that which worked successfully.
Gibby
10
Originally posted by Kevin Peng on Discord, 3 July 2025.
So you you mean you use the Openterface VGA adapter with AURGA viewer to control the WinCE, it works?
