The BT pairing PIN
Android device sees KeyMod in list of bluetooth devices ready for pairing.
Selecting the KeyMod (on the Android) asks for a PIN.
Which number should be entered?
FAQ: What Bluetooth Pairing PIN Should I Use for KeyMod?
You do not need to enter a Bluetooth pairing PIN for KeyMod.
With the current KeyMod firmware, KeyMod should not be paired through Android’s system Bluetooth settings. If you select KeyMod from your phone’s regular Bluetooth device list, Android may ask you for a PIN. You can simply cancel that pairing process.
Instead:
  1. Make sure Bluetooth is enabled on your Android phone.
  2. Open the KeyCmd app.
  3. Tap the signal icon in the top-right corner.
  4. Select Bluetooth connection.
  5. Scan for nearby devices and select your KeyMod.
The KeyCmd app should discover and connect to the KeyMod directly, without requiring you to enter a PIN.
If you’re still having trouble connecting, please let us know which Android version you’re using and what happens when you try to connect through the KeyCmd app. That will help us investigate further.
